Slight Overheating at 230 degrees
Ok I’ll be careful not to hit the fan blades.
You can hit the radiator fins, but just be careful. Keep the pressure washer tip wide. I hope I'm making sense. You want to clean those fins out, that's what could be clogged with dirt, especially if drive alot of dirt/gravel roads.
adventurenali92
Big Bear Lake, ca
Well I live down a short half gravel half dirt road off the main north side highway. Lol. So yeah I drive slowly on dirt roads. Yeah I have wide angle tips for the pressure washer. There was some nasty crap coming out underneath.... I had no idea.
My short dirt road:
Lots of crap. Doing it now?
David Smith
Savannah, GA
Yeah just put everything away. Haven’t driven yet but will shortly to see what happens. Thanks for the tips!
If that does not work, they sell a coil cleaner (at Lowes) that is for ac coils. You spray it on and it bubbles. When it bubbles, it loosens dirt and pushes it out. Once done, rinse with garden hose.
adventurenali92
Big Bear Lake, ca
Might have to look for that next time I’m off the mountain and have a lowes close by! Thanks for the tip!
HiHoeSilver
Away!
Chicago
The evaporator coil is running through all those fins. They increase the surface area for it to efficiently export heat. If they are dirty, dusty, clogged up, etc, that debris acts as an insulator and inhibits the heat transfer from the cool to the air. Keep em clean , boys. While you're at it, clean them out on the a/c condenser on your house, too.
certa
