Slow cranking due to battery cable?
My 2009 Tahoe, 5.3, cranks slow, especially when cold. It's been that way since I've owned it, but that's only been about 2 months. I had the battery load tested - tested good and it's only 2 years old. Battery shows 12.3V with key and engine off. Engine running I see 14.7 or so at the alternator and about 14.3 at the battery. Seems like that could be enough voltage drop to cause a slow crank condition? I noticed my negative battery cable is looking pretty sketchy at the post terminal. Even if it's not causing the slow crank, I'm going to replace it. I don't have any other electrical anomalies, though.
Thoughts? Would the starter itself be going bad?
View attachment 384202View attachment 384203
the proper way to test the cables is to do a voltage drop test
put a lead on the battery ground and a lead on the starter positive connection and check the voltage reading it should be the same as the battery or very close to it.
then have a helper start the engine and watch the voltage while the starter is engaged
if the voltage drops below 10.5v then replace the cable
I would check the ground ohms also from starter body to battery negative.
usually low voltage will just make the starter make a clicking noise or not even engage at all.
as others noted it could be the starter is tired. If you end up replacing it I would get oem or better (higher kilowatts)
The members of this Forum are here for you. LOTS of first-hand learned experience here with these folks.
Dustin Jackson
When my negative battery cable was broken internally I would have intermittent failure to start BUT when it DID start it was strong cranking
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Got it, thanks. I had no idea the "Big 3" mod was such a BIG deal for these trucks. I thought it was just a colloquial term amongst a small group here and an actual search wouldn't turn anything up. Guess I should have tried first! All over this site and every other forum dealing with these rigs.
Geez, man. I even gave you the quotes around it for the search term! :p
But I'm also with the others here that your starter is likely nearing its end as well. It's easy to replace on these. Just gotta take the right front fender liner out and remove the heat shield from the exhaust manifold on that side. The starter is held in by 2 bolts from the bottom. Took me maybe an hour to do it on my '07. You gotta get in there anyway to replace the cable that runs to the starter, so it's as good a time as any to replace it.
The Big 3 is likely one of the single most important "must do's" on these rigs. If you plan on keeping the rig and want "peace of mind", do the damn thing. Again, since I am a "thousandaire", I did the upgrade and a new Interstate AGM battery and a new alternator and new starter and all grounds and and and....and now, never a problem. Was a little bit overkill but I wanted to deal with it just once.
DaveO9
DaveO9
Vancouver, WA
I understand the need to restore grounds and cables to factory conditions, but why the need for upgrading conductor size and capacity so much from factory? Or is "Big 3" just replacing cables, not upgrading? (When googling "Big 3 upgrade" in a general sense you get tons of returns on high power car audio systems) I'm not into booming car stereos, kazillion candle-power lighting systems, winches or hydraulics, so I'm not sure I see any need to go beyond OEM. Same with battery and alternator.
I'll replace starter when/if I know it's necessary, but only then. I don't replace parts if I don't have to. I have plenty of experience with GM starters of old: '91 suburban and '76 vette. For the burb, I found a 1972 full cast-iron Delco and rebuilt it with new brushes, bearings, and solenoid. That beauty worked better than any junk parts store reman ever could. I should have kept it when I sold the burb and put it on the Vette.
Can these starters be rebuilt? I didn't see any kits available on RockAuto, but I didn't look much further than that.
yes they are remanufactured all the time by probably a handful of company's getting the parts may require a bit of digging.
as far as doing the big3 yes that is often done by people doing audio upgrades but it is also just a good idea since these vehicles are prone to having electrical gremlins they are very finicky with low voltage 10.5v is the cutoff, the oem grounds are minimal. some issue's that crop up can be attributed to poor electrical connections.
It's a good idea to at least add a ground from the alternator mounting bracket to the frame and increase the alternator charging wire gauge from the alternator to the battery terminal. you can call it the big2 lol.
Geotrash
Dave
Richmond, VA
I have a couple of reactions to this that I hope are helpful. There is of course nothing wrong with delaying replacement or replacing the factory big 3 wiring with new factory parts if you're not in need of better performance because the problems people are seeing are mainly the product of age and exposure - especially wet weather and road salt. But to Wes's point, the factory parts are minimal because they don't maintain the performance level that the sensitive electronic systems on these cars require for the life of the vehicle, in many cases. So the argument for upgrading to bigger/more weather-resistant components is to ensure that you're unlikely to experience the problem again. For those who keep their cars a loooong time, as I do, that's beneficial.
As for the starter, my rationale for replacing it before it fails with a new OEM part is based on not wanting to be stranded somewhere far away from home (we take trips often). And thanks to this forum, I've learned that on the GMT900 platform at least, the average life of a starter is somewhere between 120K and 160K, depending on driving habits of course. So I have a new starter on the shelf that I plan to install in our 2012 XL Denali with 132K on it in the next couple of months. I've already replaced the one in our '07 XL Denali this fall.
I have a spreadsheet in which I track all maintenance and parts replacement. In it I also have dates and mileages for when I should plan to replace common failure items proactively, based on what I've learned here. I learned this habit from owning an aircraft. While it's legal for private aircraft owners to replace parts 'on condition', commercial aircraft must have certain parts replaced after a specified time in service (hours or calendar months). What those limits are is evidence-based from past service experience. This is also true for ALL helicopters, regardless of whether it's privately or commercially owned. They do this to ensure absolute reliability and to limit the risk of failure.
It's slightly more expensive to maintain my vehicles this way, but far less expensive than a new vehicle, and cheaper than hotels, tow trucks, and a ruined vacation. And my wife and kids are usually in it with me, so I feel I owe it to them to do the best I can afford to keep them safe. So far, knock-on-wood, I have only had one vehicle strand me in 34 years of vehicle ownership. It was a Land Rover that developed a bad fuel gauge that unbeknownst to me read 1/4 tank when it was actually empty. I sold it shortly thereafter.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Exactly why, in my build thread, you have seen me replace so many items/parts/systems before they give me grief.
lordmorgul
