By 2007, the fuel regulator no longer sat up on the valve covers and is part of the fuel pump now.Sniff that hose on the fuel pressure regulator. If some fuel is sucked into the intake after shutting the engine off, the engine may be partially flooded. Once the flooded condition resolves itself, all is normal. This is an easy check. After this, start getting the FP gauge.
It could even be condensation in the plug boots, but I'd expect it to stumble for a few minutes until the moisture gets expelled from the engine heat.
Just curious where this mysterious vacuum hose is on a 07-14 ?Sniff that hose on the fuel pressure regulator. If some fuel is sucked into the intake after shutting the engine off, the engine may be partially flooded. Once the flooded condition resolves itself, all is normal. This is an easy check. After this, start getting the FP gauge.
Hi, I have a 2007 Chevy Tahoe LTZ that seems to gurgle or pudder to start on cold mornings or after its been sitting. Had the battery, alternator, and starter tested multiple times and all came back great. Replaced serpentine belt and all new plugs but still struggles in cold or after sitting 8 or more hours. Any help would be greatly appreciated. Thank you.
