So I finally got around to demolding.
biggboi
biggboi
Nice. I will be doing it within the next couple of weeks. What method did you use to take them off?
Pretty simple...a hairdryer to heat the moldings up enough to pull them off, then 3m adhesive remover for the leftover adhesive. Follow it up with a good buffing and done! Took about an hour.
davidc21a
Do you have to use dental floss to work them off? or is it a straight pull?
Thanks
Administrator
You need to use something that'll get under the molding or badges without scratching the paint. A lot of folks use dental floss, fishing line or the like. I use what is essentially a plastic spackle tool. Works great for me!!
Administrator
Thanks for the info, I'll give it a shot
:High 5: Just let us know if you have any issues or questions. Once you get going on it and do it once you'll realize how easy it really is but can be intimidating at first. :)
Administrator
No problem :High 5:
Pnut
