so just hit the housing with 1000 grit once you get the paint off then clean it off with paint thinner, but make sure it dries/evaporates off the housing before you shoot it again
you keep getting them mixed up lol
use lacquer thinner to clean the paint off and use paint thinner to clean the oils off and whatever else after you finish sanding them
and regardless if its a light coat or not, if your tails are messed with and you get rear-ended its your fault
