so i nite shaded my led tails
Oklahoma
Thats why you use LED's I never have to worry about it and mine are black.
I was the same way when I had my stocks though. Thats why I painted them then immediately went and orderd LED's.
Nick
Resident Grill-Man
TX
does anyone have a spare set of tail's I can use while i send mine to killer so he can tint them correctly? lol
07Denali
I used Niteshade on my mustang tails ans 3rd brake light. 1000 grit wet sanded them, wiped them down with paint thinner, 4 very light coats, wet sanded with 1500 lightly, clear coated with a semi gloss clear, wet sanded with 2000 and buffed. Looked like a sheet of black glass. Like the covers, but permanent. Paint work is all the same, 99.99% in the prep work.
Wet sand the clear with 1500, and re-apply clear. Wet sand and buff and you will be all good. No need to take it all the way down and start again, it is a waste of time and materials. Unless there is a run in the paint.
Are you using a gloss clearcoat? Seems obvious, just making sure it is not flat or satin clear.
WhoDatPanic
WhoDatPanic
well i re did them today i couldnt bring them back to normal color they were still dark so now i have friggin dark taillights you can still see through them since there leds but some angles its hard to see through... idk i just dont want to get harassed by cops....
WhoDatPanic
WhoDatPanic
lol i am having the worst luck... they look good now but now my friggin 3rd brake light doesnt work wtf lol the back end of my hoe doesnt like me lol... had to say it haha..
---------- Post added at 11:46 PM ---------- Previous post was at 10:25 PM ----------
the 3rd brake light is plugged in right i dont understand ? it worked before i sprayed it ? ugh anyone have any ideas?
WhoDatPanic
WhoDatPanic
do you have any idea which fuse it is i looked a lil bit but didnt find one that was burnt out?
Abn Panzer
Did you check your VEH CHMSL fuse? (Fuse box by the driver door - Fuse is just a little lower than dead-center of the other fuses)
That's the one for your 3rd brake light.
WhoDatPanic
WhoDatPanic
checked that one right now it looks good :( any other suggestions.
Slumlord24
