SOLVED No power to washer pump
Capsalot1
Capsalot1
Sugar Land, TX
BTW, how do I let everyone know how to solve a very strange instrument cluster issue I fixed the other day?
Capsalot1
Capsalot1
Sugar Land, TX
Welcome to the Forum from NH.
Pics of the truck, please.
It appears that you tested the pumps by connecting them directly to the battery 12 volt source. I am assuming that you disconnected the pumps' electrical connectors on the pumps' electrical connector pigtails. While you had the connectors apart, did you check the other end of the connectors to confirm that you are getting 12 volts to those connectors, when the pump switches are activated?
I’m on board to participate, where would you like the pictures to post?
Fless
Super Moderator
Elev 5,280
If yours is like mine, the wiper fuse is in the instrument panel fusebox, inside the cab. The washer fuse and relay I pointed out are in the underhood fusebox/power center.
Capsalot1
Capsalot1
Sugar Land, TX
Roger that, thank you sir, I’ll take a look at that relay
Fless
Super Moderator
Elev 5,280
So check this one in the underhood fusebox:
And this one (#12) in the in-cab center of dash fuse center:
DarkBlue38
