druiddonn
- Joined
- Oct 3, 2015
- Posts
- 112
- Reaction score
- 127
There’s no direct replacement speakers for our D pillars due to the oddball size, they always require some sort of modification to make something fit.I did the depillars today the speakers I ordered are supposed to be a perfect fit and they are not but they are matched to the other six speakers I need to replace the second passenger side door so I'll be waiting to do that until after body work for now 6 speakers replaced
View attachment 253060 View attachment 253061
Yeah that makes sense it's weird the way it was mounted to the trim I've only ever seen tweeters done that way as you can see from the pictures I figured something out that worksThere’s no direct replacement speakers for our D pillars due to the oddball size, they always require some sort of modification to make something fit.
Why not cut whatever is behind it, is it something important? I’m always getting my angle grinder or my Dremel out. There’s so much unneeded metal lol.and then I had to move the double USB port because the structure behind it didn't allow for clearance but I need to take the whole thing apart again whenever the vinyl wrap shows up I finally found somebody that has Denali pattern vinyl wrap
CLD tiles, CCF, and MLV isnt crazy expensive, especially not compared to some of the mods you've done! It can get very time consuming though.That’s a pretty good video. I might get a bit more serious about sound deadening in my Silverado. I did a halfway decent job the first time around but just on the inner sheet metal. Then I ended up having to remove and reinstall it when I did an LTZ interior conversion so it needs some TLC plus I wouldn’t mind doing the multilayer method. That material is expensive though.
