Spare Tire Pressure Sensor
Yeah I pressed that but I am trying to remember what it did if anything.
it's just mind boggling to me why there would be a menu item for Spare Tire TPMS Disable, so if the menu item is enabled that means it is actually disabling the function?
So I see the button to disable the function which (theoretically) if I press that it would change the spare tire TPMS disable function to disabled which would actually enable the spare tire monitoring function.
I mean who wrote this code? Translated from Chinese?
I will hook it up again and try it, so when I press the disable button the command status that reads none right now should change to something? and then I just back out of that menu and go back into the TPMS part and see if anything changed?
I would think that if you enabled it, you would have to relearn all the sensor positions to get a reading on the scan tool.
latvius
latvius
Ariton Alabama
I don't have a sensor in the spare tire but I kinda figured what someone mentioned that if I enabled it I would geta tpms warning that it couldnt communicate.
pewtermetallica
