Spark plug issues!!!
It works; on mine I had to download it. If the misfire counts are that low (<10) I wouldn't worry about them.
Having said that, #1 #4 & #5 are the ones that show a couple in the cycle. If you're concerned about those, swap the plug wire, coil, and spark plug one at a time with a better cylinder to see if the misfire follows. One piece at a time, then test; write down test results so you don't get confused about what's been changed.
EDIT: you could also have other issues causing this like fuel pressure, skewed fuel trims, but it doesn't look too bad to me.
jrmhokie
