speaking of efans....
99Yuk
Northern Ontario, Canada
Do not ignore the importance of the shroud.
I can actually feel the breeze outside the grill of the air rushing in.
Ok, point made.
For the record, I can NOT feel the air moving into the grill by standing in front of it. :)
And I was wondering if the shroud would do anything or not. Seems it does! :D
Stresst
Ok, point made.
I didn't think so! LOL If I couldnt feel anything (with my 17 fans) there is no way you could have! LMAO
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Install one of these in the hood or something.
THE YETI
Director of Operations
South FL
I have an OEM 34" radiator if anyone is looking. $110 shipped.
95TwinTT
Minnesota
Holy shit! Nice pic, know I understand what the TT means in your username! Have any quarter mile #'s? What are your 60' times?
Planning on getting to the drag strip, next Wednesday night. I expect to work on the 60' times with the new 4500 rpm TC, using 4 wheel drive. Should be interesting. :)
AtomicHoe094
Atomichoe094
cleveland, OH
haha Del, looks sick!
Also, is it normal to feel warm air right outside the grille when the fans are on? i think one of mine is wired wrong. Ive always thought that from the beginning but these things still keep the temps down.. idk weird..
95TwinTT
Minnesota
I can’t feel any warm air in front of the grill, only feel a breeze going in, nothing coming out. You should revisit that wiring.
I didn’t use any of Flex-a-lite’s wiring or controls. I did check polarity before hooking them to the relays to be sure they were pulling. I have a separate 40 amp relay on each fan. I plan on hooking up a “hi / low” switch at some point for one or two fans. I want a switch that selects, left, right or both. That way for the spring and fall, I can just run one fan and wear them evenly by switching the duties every other day, from left to right.
The Orange monster is looking good…………. :)
SunlitComet
OBS Jedi-Do Good
You are probably feeling radiant heat or the wind blowing some surface heat back at you.
---------- Post added at 09:22 PM ---------- Previous post was at 09:19 PM ----------
Lets call it the pumpkin.
BurbyRST
