Spider Injectors
SunlitComet
OBS Jedi-Do Good
unknown at this time.
dumb question...did you mess with the dizzy at all??
No question here is ever dumb.
---------- Post added at 06:38 PM ---------- Previous post was at 06:29 PM ----------
I would like all parameters if possible in a Log file say about a few minutes long with a couple of minutes of idle hunting and say one or two at about 2500rpm. Would also need the software version details so I use the right one. Have not used it myself yet but developers usually will let your download it and playback files for a demo without any cost. So I would like to try on yours if you don't mind.
Phone Man
Phone Man
Long Island NY
Set it to "0" with a scanner.
Replaced:
TPS
EGR
IAC
MAP
MAF
VSS
Temp (both)
Cam Pos
Crank Pos
Computer (stock and BB Tune)
Cap
Rotor
MSD Coil
8mm MSD wires
Plugs re-gapped t0 .060 (plugs normal color)
Alternator
Throttle Body 2x
Intake gaskets
Upper and lower manifolds
Plenum spacer removed and reinstalled
Engine
Tranny
Air fresheners
This started out of no where. It only happens in gear, not in park or neutral. Also high idle before coming to a stop, then goes down to normal... hangs in the normal range... then starts fluctuating more and more until it bucks into a stall. Restart, and it's ok until it acts up again.
Tried something the other day... Unplugged the harness from the tranny, started it up and it went ito its hissy in park. Hmmmm. Ran out of time to do further investigatiing.
---------- Post added at 09:52 PM ---------- Previous post was at 09:49 PM ----------
Thanks Sunlitecomet. I'll post the version. How can I get you the LOG file?
stuntmanray385
hey 99yuk where did you order the spider upgrade? how much? and also whats the difference from the stock injectors?
99Yuk
Northern Ontario, Canada
I had to order mine from rockauto.com. They had the best price for CDN buyers. In THIS thread, I had found the best price for US buyers was from Amazon. A few members here have purchased the one from Amazon with good results.
bubbap609
