Squeaky noise coming from the outside of 2007 Escalade... what could it be?
Administrator
Good point Edgar! I also dealt with that on my rear brakes when I first got my burb. :waytogo:
jmaiers
I got the same noise coming from my LTZ. i had the front right hub changed and new pads put on the front. noise is still there. I took the dealer shop foreman out and he said could be the front left hub then said it could be a brake clip contacting the rotor......Either way, warranty is covering it so they can have at it. I will let you know, goes back sunday
yates ™
Resident Apple hater
Iowa
Thanks a ton Felix!! I drove the Yukon today and by god a freaking squeaking noise!!! I hold you personally responsible for this...
felixgun
felixgun
Lafayette, LA
Ok sounds like hubs and pads could definitely be the issue. Good to know thanks for the info. Let me know how it turns out and what their diagnosis is!
---------- Post added at 01:51 PM ---------- Previous post was at 01:47 PM ----------
LOL it's contagious apparently.
yates ™
Iowa
I was on my way back from lunch, had my windows down, no music and immediately started cussing your name for giving my poor Yukon this illness
Administrator
Yates....you should be thanking Felix for starting this thread for you so that you, too, could know what the possible causes might be :deal:
yates ™
Iowa
I guess I know what I will be doing this weekend
Administrator
It's a good weekend when you get your fingers dirty :)
yates ™
Iowa
You coming up Saturday to help?? I will feed you...
Administrator
I definitely would (especially with being offered food) if I had the time but my weekend is jammed full of stuff. :-s
Alsherooqi
