Stability control light will come on and go off at my Tahoe 2007 LTZ
DJPoertsch
DJPoertsch
Hallo all my friends. I want to clear some open questions. First of all I was installing an Prinz Vsi 2 LPG system into my truck. So this runs great. As I was writing down I had this problem only when it's very wet outside. So I was inform my Garage where I was installed the log system. We connect the PC to check the Prinz system.. I was driving all the day and up hill and down hill. At this time when I was there the Failure never would come up again. I have no idea what was the reason for this problem.
From that time till today I also had some bad raining days and also then the failure was not coming back on again. I was checking with tech 2 also the PCM but all was clear.
I think I had some gizmos in my truck. But till today all is fine an runs good at the moment.
Greetings Markus
Greetings Markus
Good to hear. Hopefully all will stay good.
David Smith
Savannah, GA
Greetings Markus
Check your brake fluid. My friend has this same issue is he takes a left hand turn too fast. He added fluid and it stopped. Worth checking...
Ejwr
