Stable trac problem
Tawas23
2006 Yukon 6.0 stable trac message comes up and a hesitation with a quick 2 second vibration noise near drivers side engine area ..cannot figure out how to fix this ..when I disable the stable trac button everything is fine ..does this random only sometimes..but no issues when I disable the system ..any ideas
Duramax05blk
NH
my 03 says auto track i believe. Any ways the vibration is the brakes engaging to limit wheel slip which the system believe's is occurring. usually its a bad abs wire to the wheel bearing or may need a new wheel bearing.
---------- Post added at 02:17 PM ---------- Previous post was at 12:46 PM ----------
Traction active is what dic says when similar problem occurs
Sent from my iPhone using Tapatalk. Excuse my grammar the iPhone makes me iStupid!
T
Tawas23
ok I will pull wheels and check all ABS sensors ..clean and try thanks
