Steering position sensor? EVO sensor
Jaycenk
Florida
Ok I have a problem with the way the truck dives. As I am driving at times the steering is nice and tight just like it should be. Other times If I so much as touch the wheel the truck is tring to jump the median. I of course changed steering boxes and rebuilt half of the front end that did need it but did not fix the problem but made it worse because everything is real tight now. Also the air bag light came on after I changed boxes. My intermidiate shaft is being replaced thursday because it is f'd up and not on the box threads straight. It is now to f'd to figure out where it is supposed to go and has some slack in it so I ordered a new one. I did a search and found out that some tahoe's came with what is called EVO or a steering position sensor? I have no idea if mine has one or not. Is there an RPO that will let me know? Do you think this is my problem? where do I get the sensor from? thanks guys.
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
theres a grey disc on the steering shaft above the brake pedal thats the evo sensor-autozone has them for $40
Jaycenk
Jaycenk
Florida
Yup I changed it today man what difference. I can't belive that thing was causing all my problems.
wicked2000
El paso TX
Does a code go off when the evo goes bad? Mine is a 00 z71 you think I might have it?
wicked2000
El paso TX
Steering feels soft. What is it that this sensor is suppose to do. I have to make sure keep my hands on the wheel dont want to curve check wheels.
wicked2000
El paso TX
Not a member of Tahoe Forum so i cant view pics. Tried to join but no luck. I beleive my truck does have it because I saw a round plastic disc on the shaft, havent gotten a chance to really look at it good. can anybody post up pics?
fastard
