Steering wheel play
denalianyone
NYBlackLade08
New York
My steering has no play when the engine is off but once I start up my truck there is a little play to the right. Steering to the left is tight, I'm confused.
zaathur
if all inner and outer tie rods are good along with pitman arm its more that likely the gear box
denalianyone
denalianyone
NYBlackLade08
New York
I just replaced the gear box and that took most of the play out. Inner and outer rods r relatively new too.
WHITEOUT
Dont Hate-Appreciate
Phoenix
Guessing you replaced pitman arm as well? As well as Idler arm, and also Idler arm bracket. Most people don't replace that, but can cause play if worn. I just replaced all of it, and have no play now.
denalianyone
denalianyone
NYBlackLade08
New York
After I replace the idler arm bracket would I need to get an alignment...I would hate to get another alignment after getting one just 2 weeks ago after installing the djm control arms.
TailHook
Tattooed Millionaire
Arizona
Since the idler bracket doesn't adjust geometry (toe/caster/camber), shouldn't have to get a new alignment after replacing...the only thing you might notice is that if it was really bad, your steering wheel may not be straight.
dylansmashed
