I'm in the process of starting my system in my 03 tahoe.
im trying to find out the largest speakers some of you have put in the rear doors.
my plan was 8 8inch mids, 4 super tweeters and a pair of compression driver that i have.
however i was just offered to trade 8s for 10s.. if i did 10s id do 2 in each front door but i see no real possible way to get a 10 in the rear doors.
if its gonna take way too much work i'll just stick with the 8 8's, 3 in each front door and a single in the rear doors.
the rest of the build will consist of:
Dash: Nexus 7 tablet with Pioneer 80prs
DSP: Rockford 3sixty3
Speakers:8 PRV Audio 8MB450
Tweeters: 4 PRV Audio TW450Ti
Compressing Drivers: 2 PRV Audio DT175 Horn with short body horns(crossed at 2k-6k)
Amps: All Taramps, sub amp hd8000, mids amp ts1300x2, highs amp ts600x4
Subs: 2 FI Team15s
4 320 amp iraggi alternators
6 runs of 4/0 wire
ton of audio techniks deadener
6 Duracell Group31 batteries / 2 Duracell Group34 batteries under the hood
running less than this with 8k rms i had .4 voltage drop starting at 14.8 to 14.4 full tilt. this time around i may not have any voltage drop with all the alt power let alone backup from batteries
if i decide next year to change amps to ct sounds 4ks i'll get xs power 16v batteries and run external regulator for a 18 system
but that might be overkill.. this setup is already gonna be overkill and my wife is hating ever bit of it b/c how much its costing... but i work hard so i play hard
Subs: 2 FI Team15s
6 runs of 4/0 wire
