Stock battery just crapped out @ 36,500 miles... Just an FYI
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Not as much cold. Lots more humidity. Heat sucks. I hope that helps Derek.
Kirk, I had a similar problem with my 06 supercharged (from factory) Cobalt. This happened once in Utah and again in Virginia. Going aftermarket, and buying a bigger and stronger battery, solved that problem. However, my wife's 07 Cobalt with the 2.4 is over 5 years old and still on the same battery that came with the car when we bought the car brand new.
yates ™
Resident Apple hater
Iowa
Very much so :Handshake:
I think my first battery lasted 60K, the second not as long but I had other issues.
---------- Post added at 10:20 AM ---------- Previous post was at 10:19 AM ----------
But you know Florida? Hmm...
I just know it's warmer all year round, no snow, and beaches. I do not know that much about it but more then NC or VA :shrug:
Modded
That Guy
Replaced mine with a Duralast Platinum at 20k miles just in case.
I just bought two of these batteries the other day for my dual battery setup. They are very nice (better than Optima). They are also the same as the Deka Intimidator battery so they are good for aftermarket electronics.
My stock battery took a dump at right under three years and about 25000 miles.
Denali0229
FL
Mine was pretty weak when I bought the truck with 58k miles so I changed it. I'm not sure if that was the original battery or not though.
Ta6112
