Stock cluster with trans temp gauge
04_Z71_tahoe
I need a good close up of the trans temp gauge on a 04. I going to put a stepper motor in my cluster and make my trans gauge work. I want to see how the numbers is set up so I can put some on mine so I know what the temp is. You can post it on here or email it to me. My email is [email protected] thanks in advance
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
you can just buy the complete overlay for $80.
Trans isn;t a separate gauge overlay that you cna run off with a vinyl printer.
don't understand but ...
there are plenty of pics on e-bay or z-71tahoe-subarban.com if you are looking to add numbers on top of the existing 'Double D' with rubbing transfer or something?
04_Z71_tahoe
I don't want buy a 80 overlay I don't like most of them I'm just going to add a stepper to my stock cluster for the trans temp Does anyone have there stock over lay with the trans gauge that you took off. For a 04 with steering wheel controls and with the info display under the P RND21
Eagle
EL PASO, TX
Excuse me for trying to help you.
$80 is the cost for the STOCK 2500HD Overlay you are looking for. The crappy 'ugly' ones cost far more. IE $80 is the 'cheap' option.
BTW It is also called an 'applique'... for GM the word is apparently synonymous with "whachamacallit."
Unfortunately for you and I, unless they are busted, the clusters generally sell complete, since the clusters are worth more complete ($150-$250) than the overlays are worth new.
If you really hope to find one used, you might want to put up an ad on GMFS.com in the classifieds where you are far more likely to find 2500HD owners that might be upgrading to blingy shit.
DItto for here, If you want to make a parts wanted thread, you need to post that in the Classifieds when you get 45 more posts
tybardy
everyone needs a Hoe
Gilbert Arizona
i believe if you buy a denali or escalade cluster, the trans temp gauge just works.
---------- Post added at 06:39 PM ---------- Previous post was at 06:37 PM ----------
lol, just read the rest of the thread.... i eat my words now...
but still, buy an escalade bezzle...
04_Z71_tahoe
Sorry man I didn't mean to come off as a butt. So 80 for one ok I just didn't want to get a aftermarket one right now. I will see what I can find maybe at the junk yard
Spooner
Austin, Tx
Do all SUVs come with the plug for tranny? I would like to do this swap in an '01 tahoe but not sure if the plug is there...
thumper_ehhhhh
Canada ehhhhh
The temp reading for your tranny is already in your computer. All you need is the correct cluster. When you plug it in it should work. You cant just buy a single guage the cluster comes as a whole unit I beleive. I personally dont like the look of it. I'm leaning towards a OBD2 reader for my Burb. Good luck on your search.
04_Z71_tahoe
The spot is there in my cluster looks like you can put a stepper motor and a light and it looks like it would work and have a over lay with the temp gauge
Badluck
SE WI
Yes you can add a stepper motor to your cluster but, I've read that it is hit or miss if your cluster will show the tranny temp without getting the cluster programed @ the dealership.
bunerosa
