Strange creaking noise from brakes
nonickatall
Germany
Ah, ok.. Thank you...
I didn't know the English word for them. We call them "Kardan Gelenk" in German, thought you call them cardan shaft...
nonickatall
Germany
Most(U.S.) call them U joints or Universal joints. And the driveshaft is typically called a Propeller shaft in the books.
That is something sometimes very difficult for foreigners, like me, when you speak a language not like native speakers and then you try write about technical issues and looking for words and try to translate that and get totally wrong words.
That remind me on a funny scene that I had once with the foreigner in Germany wich wanted to tell me that she knew a woman, which was going for a surgery to remove a rib, to get a "bee hip".
And I asked her. A bee hip?
Until I came to the idea that she meant a "wasp waist".:Big Laugh:
03GMCYukonXL
03GMCYukonXL
Defnitely sounds like a bearing but the resonant frequency does not sound like it is traveling through steel. Its sounds like it is traveling through aluminum. Check your U joints.
The tire is turning well less than a quarter turn everytime it squeaks. That leads me to believe it is not the axle bearing since they typically get pitted in a certain spot or area and that would require a complete revolution of the tire(axle) to make the squeak. Not a fraction of complete wheel rotation.
I assume by U joints you mean the drive shaft joints? I will check them but I assure you that the noise is coming from that hub somewhere. It a lot more obvious when you're there than it is through video. But hey what can it hurt for new bearings anyways right? I'll change them and if the sound persists, I'll update this thread.
Are you sure that the rotor isn't rubbing the splash shield? Were the splash shields in good shape?
nonickatall
Germany
but as @rockola1971 rightly pointed out, this noise is not once per revolution but about every quarter of a revolution. That doesn't really go with splash shields.
03GMCYukonXL
03GMCYukonXL
Also, it doesn't do it when the car is jacked up. It's only under load. Splash shields are pitted and rusty but not misshapen. Like in said, I'll change the bearings anyways because it's can't hurt.
Is hub clean so the rotor sits flush? No rust jacking on the hub?
nonickatall
Germany
It don't sound like a rotor touching something and the noise is every quarter rotation. That don't fit to problems with rotor.
And when it is only under load, I would say: wheel bearing.. When rotors make noise, they do it without load as well, or during brake. But rarely only unter load of the wheel... In my humble experience...
Don't you think?
Scpori
