Strange Issues. Please help a brotha out.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
It says 2 of 2. What is/was the other code? Plus that says it is a history code. If you are not experiencing any anti-lock brake or regular brake problems, I would make note of it and clear it and see if it comes back.
That code could also be related to your replacing that brake light switch.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I'm new here. Quite active on a similar Camry forum, but just joined this as I also do a lot of work on our 2003 Yukon Denali XL 6.0L V8, nearing 180K miles.
Welcome to the forum from Oregon and thanks for the video.
To that end, and if you do end up having to remove/replace your wheel hub and speed sensor assemblies, I have done that twice on our rig.
Both times I've gone with the Timken SP500300 assemblies, which are some of the best. Had a lemon pair once that were easily warrantied, but that can happen with any auto part. AC DELCO may also be a good choice. Stay away from MOOG.
This was a helpful installation video for me the first time (as are many videos from 1A Auto):
Second time I did the install from memory; basically it's a little more involved than a full brake job.
The hardest part may be getting off your hub/axle nut...unless you have an impact wrench, which makes it a super easy 10-second removal. (In fact, I first bought my impact wrench several years ago specifically for this wheel hub job, and it has become a mainstay in my garage. Well worth the investment if you're going to continue to work on your rig.)
Hope that helps.
if he had a problem with a hub then the abs light would be on or there would be brake pedal abs feedback when stopping or he would hear grinding noise, a bad hub would not trigger a stabilitrac/traction control code, just abs even though they are related the abs code would take priority.
kbuskill
NE. FL.
Will clear the code tonight. And see what it does after I put the plugs and wires in this wknd. Did buy the ac/delco iridium plugs and the ac/delco wires.
Did changing the crank sensor not get rid of the lights on your dash?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Now you can start fresh and address any codes that may pop up later that could be legitimate codes to deal with.
SinStar999
