Strange Noise on Drivers Side.....
Radz156
I don’t believe it is wind noise. The fact that it happens mainly on deceleration and coasting, it could be a vacuum leak somewhere as Derek suggested.
Might try holding or taping the phone in different positions like under the dash or if you’re brave to the top of the fuse box cover under the hood to see if that helps pin point the sound better.
If you roll the window down and stick your ear out the window can you hear it from outside the vehicle? If your wife drives past your house and decelerates, can you hear it while standing beside the road?
I am having the same problem. I had exhaust gaskets replace and didn’t help. I have a 2018 Yukon SLT. I’m taking in to have driverside door speaker replaced. Will update later. Thank you .
jgrundy13
