Grizzly
First off, It's nice to see you all again! It's been so long. But I am here seeking some insight and kinda desperate help...
Here is the deal, I have a 2004, Chevrolet Tahoe Z71, 5.3. I have had this strange popping noise for at least 6 months, (Cold weather and Warm). It only happen when I hit bumps, accelerate quickly, braking etc... Little bumps in the road and you can sometimes hear it, It's a very distinct popping noise or like a clink? It FEELS like it is coming from the driver side towards the seat? So now you know what the noise sounds like, let me continue. I recently (about a month ago) had to replace the water pump because I was going through a gallon of coolant every 2 days... Once I had it replaced the NOISE stopped, completely. So I thought GREAT it was just the water pump, two birds with one stone! I was wrong... I was on the freeway going about 75, had a idiot pull out from the pull off lane with no blinker, I jerked my steering wheel to get out of the way... SURPRISE! It's back... The popping noise returned that night, and it seemed worse when I put more people in the car... So I took it to a shop and was told I needed new shocks, and I wasn't surprised because it had the original shocks and I am about at 180k miles. So I gladly spend 500 dollars getting new shocks (Top of the line), on my way home... It started AGAIN. I then went to about LITERALLY 7-8 Mechanics I had two say it was the Pitman Arm and the Idler Arm, then two others said it wasn't and that they are tight, I then had another tell me the Transmission Mounts needed replaced, Then I was told it was the Intermediate Steering Shaft(which is what I suspect.). No Mechanic can give me a straight answer... I have had two places keep it over night and spend HOURS trying to find the problem with NO luck.. I don't wanna throw parts into my Tahoe cause I can't afford that. To sum it up- Popping noise from the middle driver side when hitting bumps, dips, accelerating, braking, etc. New Shocks, and My car is a giant iceackle right now from the snow I got last night and it's like 5 degrees... But the noise is GONE as of right now only cause the cold (I'm thinking whatever it is popping has ice in it or something. But I KNOW it will return)... Anyone have ANY ideas of what it could be after explaining the above? ANY insight will be of GREAT help... I really don't know what to do...
