Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Noticed my tranny fluid was running quite a bit low the other day when changing the oil. Where the heck do i add fluid at? Nothing in the manual!
Does it go in the little tube where you check the fluid levels at?
2001 Yukon 5.3 2wd
Yes i checked it while it was running. Looked about a quart low.
Thanks, i just wanted to make sure. Looks like i need to go buy a small funnel. As usual thanks for the help!
Yes, narrow neck funnel added to where the dipstick goes. Add only 1/2 pint at a time and recheck. DO NOT OVERFILL...I've been told nasty issues if you overfill. On my 2002 tahoe, 1 qt low was basically below the min level (below the level of the crosshatches on my dipstick), barely seeing any on the bottom of the stick when checked hot, just for your reference.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
