Stupid oil leak
992dr
Eastern N.C.
I had a random leak, looked like it was the rear main seal or around that area. I put in Bar Oil and its stopped it (for now). Sucks because it sprayed oil all over the undercarriage of the truck. It sucks because it really made a mess under there, especially on my Thorleys.
I need to do one of those dye tests.
ncdrtyhoe
ncdrtyhoe
No kidding I found some of the UV stuff on ebay for $4.99 obo and $4.99 shipping!
ncdrtyhoe
ncdrtyhoe
Anybody know where the oil pressure switch is located? I heard it was around the rear of the engine but I can't find it!
oldsalt
Drivers side. Look under the plug wires at the distributor. Black cylinder about 3 inches long pointing toward the passenger side. Plug on the end.
It's a ***** to get out. Especially if you are tall.
ncdrtyhoe
ncdrtyhoe
Great I think that is where my leak may be comming from! Thanks!
ncdrtyhoe
ncdrtyhoe
ok got the UV oil leak stuff and a handheld blacklight ready to track this leak down! How much of the 1FL OZ bottle do I put in the engine oil?
luderacer
thanks for that info as well Diller going to note that down in case i have any leaks down the road.
ncdrtyhoe
ncdrtyhoe
Well I think I tracked down my oil leak. When the oil filter adapter gasket and seal was replaced I used the dorman part number 82560 which had a metal plate gasket that goes inbetween the filter adapter and block. It had blew out under pressure and the oring was flat. I went to the parts store and go the felpro oil cooler gasket set part number ES 72671 with a paper gasket and new orings that are much better quality. So far so good working good. The oil was all over the bellhousing and back thrid of the oil pan like it could have been the rear main seal but thank goodness it wasn't.
Lowbrad
