Subwoofer in 2dr tahoe
dirty96hoe
Here is how my sub is setup from previous owner
ChiTahoe
Looks good, here is a design i found online I'm planning on doing down the road. Fits on the right rear cargo area.
X3N0N
little confused on the diagram... so the depth is 6 1/2"???
X3N0N
I see... im actually building this enclosure right now but going with different specs of my own and its going in place of the spare. More room on that side with the spare stuff taken out. Also using 3/4", 1/2" just seems to small.
ChiTahoe
I think the depth is 5 1/2 cuz its 1/2 om front and rear of MDF, It should work for a small 12" bump.
96ProCompTahoe
IN
Other than a box built into the side as shown in previous posts theres not a good place to "hide" subs in a 2-door. 10's would be a tight fit under the back seat but could be done. been debating what im going to do with my 12's since my 35x12.50 spare won't fit with the current box.
Always wanted to try my hand at a fiberglass enclosure... :D
BigDaddy13440
Rome, NY
I cut out the inner steel quarterpanel on my 4-door, and cut the fiberglass trim around the window. Fabbed up an enclosure to follow the contours of the space out of 3/4" MDF, then fiberglassed everything in place. Lastly, carpeted the enclosure, and made a plywood grille to go over the sub, preventing anything from sliding around and damaging the sub. About 2.4-2.5 cu ft internally, with the port displacement and sub displacement (Celestion AD15H), I've got just about 2.0 cu ft.
And I have one on each side..... still working great after almost 3 years.
Still have 49" from wheelwell to wheelwell, enough to slide a full 4x8 sheet of plywood (or anything else) in, and have it hang out over the back of the tailgate, or stick out the hatch. As an aside, if I've got something heavy, I'll support it by placing a 2x6 across the top of the two enclosures, which are even with the top of the tailgate - this way, I don't stress the tailgate hinges.
---------- Post added at 05:28 PM ---------- Previous post was at 05:23 PM ----------
Or, you could just build a center console, have the subs fire downward, mount the amp(s) under the seats.... I fabbed brackets to move my seats about 1 1/2" towards the doors, gave me almost 14" between the seats to build the enclosure (for two Powerbass 10's, and 3 amps mounted underneath).
Yeagermeister84
