Switching into 4 wheel high low auto randomly.
04hoho
Truck will pick its own 4 wheel drive mode at start up every now in then it says 4 wheel low but the rpms are not high enough. Others it will start out in 4 wheel auto and then if you stop and put in park an switch to 2 wheel you can hear it disengage any ideas????
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Very common issue.
Transfer Case Encoder Motor Position Sensor.
http://www.amazon.com/Dorman-600-120-Transfer-Motor-Encoder/dp/B004GBAPC2
You can do it yourself which costs you about $45 or have a shop tell you that you need a new encoder motor which with parts/labor will be upwards of $900.
Don't know why this subject hasn't been stickied before as it has been covered a million times.
If the motor moves positions it's not the motor (because the motor runs) itself which is $$$.
Buy the part above and do the following:
http://www.fullsizechevy.com/forum/...-encoder-motor-sensor-replacement-w-pics.html
cjprod0684
