2drTahoe97
- Joined
- Jan 19, 2025
- Posts
- 2
- Reaction score
- 0
I just bought a 1999 Tahoe with many issues. Todays project is the tailgate latch wouldn't release when you pulled the handle. 1st problem was the striker pins didn't have the plastic sleeve on them (long ago crumbled to dust). I replaced the pins and still couldn't get the tailgate open. The guy I bought it from got the tailgate open by pulling the handle and simultaneously turning the key. I adjusted the lock rod that rotates the bell crank until there was no freeplay, still wouldn't open. I put vice grips on the lock rod that goes out to the latch and pushed, still nothing. Then I put the vice grips on the rod the electric actuator puls and worked it back and forth. Then things started working.
I noticed that the push rod that goes to the key also pushes up on the latch that the window latches onto. That part looks bent or definately not factory made. Is this right?
![Tailgate Latch.jpg Tailgate Latch.jpg](https://www.tahoeyukonforum.com/data/attachments/444/444180-adcc234763537fa453aaf30ab44724ba.jpg)
