Tailpipe Smoke???
Smasal
Smasal
Southwest, Mo
Clean.
Ch@d
AtomicHoe094
Atomichoe094
cleveland, OH
regardless if the tank and radiator is "full", your plugs and the white puff smoke is making it look like your eating antifreeze..
plugs shouldnt look like that after only 12,000 miles on a brand new engine...
Smasal
Smasal
Southwest, Mo
K so I need to find out how it's getting in there? Cause I assure you there is just under 13k miles on this engine. What cause me to eat antifreeze?
Ch@d
Smasal
Smasal
Southwest, Mo
I know better than to lead u guys on about something on the truck. I know the more accurate I am with information the quicker and better u can help. Should I check another plug? See if same results?
Ch@d
gpracer1
Phoenix
If I was to guess I would say valve stem seals leaking oil.
If it was antifreeze, it would turn to steam but never make it out the cold exhaust system to the tail pipe without condensing back to liquid......just thinking out loud, could be either.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
not near a coolant passage intake wise and would unlikely be affected by coolant unless the head or gasket cracked and it looks good for a platinum plug. Can you examine the others please?
Edog911
