Tall jack stands for transmission removal from 2013 Escalade ESV
Geotrash
Dave
Richmond, VA
The more I think about it, I am going to do a functional test of what I have. I will jack up my Escalade with:
-3 ton jack stands under the rear axle, as high as they will go
-6 ton jack stands somewhere under the front frame, as high as they will go, sitting on 2" thick wood spacers
I will raise my transmission jack as high as it will go, and see how it all is. See how much room I have, see how well the transmission jack gets to the transmission.
Then buy more stuff accordingly.
If it helps, I believe the 6L80 is 18" tall. So adding maybe 6" to that for the transmission jack, you'll need about 24" of clearance to roll that thing out from underneath.
skpyle
skpyle
Thank you! I appreciate the information.
Ta6112
