Tapping getting louder. Can’t pinpoint and have tried stethoscope to no avail.
iboughtatahoe23
iboughtatahoe23
AllDataDIY for an online subscription is also an option.
I actually don’t even see a Haynes repair manual for my car; I see a 2007-13 gmc and Chevy Silverado manual that’s about it. If anyone has a link pls share. Mines a ‘14 so I know there was some differences between the ‘13 and ‘14 year
Fless
Super Moderator
Elev 5,280
Haynes 24067. Includes Tahoe, Yukon, Suburban, yada yada yada Can be found on Amazon and other online retailers.
Rock Auto:
Opened up the flexplate cover and inspected. Looks fine. Just a little surface rust here and there. Not sure how to rotate it. Look like I have to take a cover off? Not the whole transmission pan though right?
My flexplate cover, not sure what to do next.
You need a bright light and to check further up in there. You were correct in pointing out the torque converter and, no, you're not gonna be able to move it forward or back by hand. About that part of the vid is where you actually had some light further up where you need it. It's a narrow gap, but you wanna look up towards the center where the six bolts are. There are three points where the torque converter is bolted to the flex plate. The more common area to crack is around the six bolts where the flex plate bolts to the engine's crank shaft. Here's an example:
You'll be looking at it from the side and through that narrow gap. So, take your time and look very closely cuz they'll be hairline cracks and not so blatantly obvious. Move your light around a little to try to illuminate the area from a few angles. As Nick suggested, the mark on the flex plate is just so you know you've viewed it a full 360°. You'll need a 15/16" or 24mm socket on a large ratchet or breaker bar to turn the engine.
Here's a breaker bar on the crank bolt, viewed from underneath. The plastic splash guard was removed. I think that's only four bolts- 14mm or 15mm:
Actually, I was rotating the engine to remove the three torque converter bolts:
iboughtatahoe23
iboughtatahoe23
Ok so I can attach on any of those bolts to turn it after marking it? And I can use two wrenches instead of a breaker bar? I don’t have one at the moment.
iboughtatahoe23
iboughtatahoe23
Like what?
It's a GMT900, "they" usually only list them through 2013 as that was when the 1500 pickup production ended for that generation.
And for instance, I was pretty sure little things like the maf sensor are different from 13 and 14
No! Don't mess with those bolts! lol
I was removing those bolts in preparations to remove the engine. That's the only pic I had of that area. Ignore the wrenches. I posted it for reference so you'd know the three bolts nearest the outer edge of the flex plate are for the torque converter-to-flex plate bolts. The bolts you need to check are the flex plate-to-crank bolts, located near the center of the flex plate. There are six of them in a tight circle. If you refer to that first pic with the cracked plate, you'll see the six shiny circles around the holes in the center. Those are the six bolt holes. They're not near the outer edge of the plate, but near the center. So, looking through the inspection hole, you'd have to look further up.
To see all the way around it, you'd need to turn the engine. To turn the engine, you put a large ratchet on that large bolt head in the center of the pulley on the FRONT of the engine.
Picture this: You're laying under the car, at the back of the engine/front of transmission, looking through the inspection hole.
Draw a mark on the flex plate. A line, a circle, a star, a happy face, a penís- doesn't matter.
Shine a bright light up in that tight gap between the converter and plate, towards those six bolts way up near the center of the plate to look for tiny hairline cracks.
Now, slide forward to the front of the engine to where the crank, serpentine belt, radiator, etc. are located.
Put a large ratchet with a 15/16" or 24mm socket on that bolt that's in the center of the crank pulley and turn it 45° to 90° or one ratchet pull or whatever you wanna make it. The exact degrees doesn't matter at all. You're just rotating it to see the parts you couldn't.
Slide back to where you were so you can look up through the inspection hole and look again for cracks. You'll notice that the penís you drew on the flex plate is no longer in that same position because the flex plate turned. All good.
Inspect for cracks.
When you've looked enough, slide back up to the front of the engine and use the ratchet to turn the engine another 45° to 90° or one ratchet pull or whatever you wanna make it.
Slide back to your inspection hole
Turn the crank, inspect, etc.
Repeat until that penís on the plate is back in view, indicating that you've turned the engine a full rotation, plus or minus a few degrees, and have inspected all around the plate for cracks.
*NOTES*
If your splash shield is in place, you can remove it to access the crank pulley from underneath. It's just four bolts. Or, you can get out from under the car and reach down from the top of the engine bay to turn the crank. I think from underneath is easier.
The engine will be easier to turn at some points and harder at others. It might start out turning easy then feel like it just locks up, maybe tries to turn backwards against you. It's not locked up and you are not damaging anything. It is just because you are on a compression stroke of one of the cylinders. Just pull harder and more steadily on the ratchet and hold for a few seconds. The compression will bleed off and it'll turn and stay where you turned it. You're not turning it much at a time, anyway.
iboughtatahoe23
iboughtatahoe23
Inspect for cracks.
*NOTES*
I’m at work I kinda skimmed this… will come back to it. Is there any videos I could watch about this?
quikdime
