KVacek
- Joined
- Nov 6, 2014
- Posts
- 56
- Reaction score
- 38
My wife's 2005 Yukon Denali 6.0 had the evap codes maybe 5 tears ago. The lines were all good, and one by one I replaced the valve at the canister, the gas cap, and finally the valve on top of the engine - the easy one to get to. That fixed it for years.
Now she has a P0442 MIL - Small evap system leak. I tested the vacuum holding of the evap valve on top of the engine first, engine off, no key. It only holds an inch or two of vacuum, so I concluded it's bad and ordered another AC Delco (GM 12581282 - Delco 214-1105). Came overnight and since it's raining I decided to test it before installing it. If I don't hold my finger on the bottom (goes into the engine) side, it leaks pretty much the same as the one already on the truck. Checked my hookup, checked my MityVac, etc. I can pull and hold good vacuum on the MityVac and my hose. Attach the valve and it leaks.
One video mentioned that they always test them and have had bad ones from new. It's a real Delco, original part number, as far as I know.
Is it likely it's bad from new?
