Sparksalot
All three of mine have/had 3.08. It’s what PPVs come with. Why anyone ordered 4wd with that is a mystery. So is the block heater in Texas.You only have 3.08 gears? Thought these with the 6 speed came with 3.42
I think @Doubeleive has something similar on his truck.Anyone ever used one of these?
2007-2020 GM w/ 6L80 Heavy-Duty Cast Aluminum Transmission Pan
Ditch the grit. Get rid of the dirtiest oil left in the valley of your stock pan from all your previous transmission oil changes. Upgrade the stock stamped steel pan to the PPE Heavy-Duty Cast Aluminum Pan. A conveniently located one-inch drain plug promotes a full transmission fluid drain...ppepower.com
I'm going to do a fluid and filter change around 5k miles, just to ensure that any shrapnel that was left in the lines doesn't continue to circulate, and I'm thinking I may as well upgrade the pan while its off...
I have the B&M pan on both the denali and the silverado, it's pretty much the same as the ppe just seemed like the B&M pan was better quality, I think the B&M is a tiny bit more like $370 or somewhere around there last time I looked. B&M is owned by Holly so I would check the holly website for more info.I think @Doubeleive has something similar on his truck.
Do you feel like it was money well spent, or just "eh"?I have the B&M pan on both the denali and the silverado, it's pretty much the same as the ppe just seemed like the B&M pan was better quality, I think the B&M is a tiny bit more like $370 or somewhere around there last time I looked. B&M is owned by Holly so I would check the holly website for more info.
Extra cooling + extra capacity= money well spentDo you feel like it was money well spent, or just "eh"?
TruCool 40K is going on tomorrow. I'll be doing one of these later in the year with 6AN lines from trans to cooler, to make sure the trans gets up to temp on my 25 min drive to work.Especially after installing a TruCool 40k
Ice cold trans temps is where it's at yo!
