There are just some days I wish I didn't turn wrenches
GMT800 SUV/Trucks
I personally would start by checking to verify that each wheel has a TPMS in it, and that its broadcasting.
In my area, you can take it to a local Discount Tire, and they will setup the TPMS for free, as long as they dont have to put it on a lift.
Sorry, should have said this. When I checked the air pressure, I did verify that there is a sensor in each wheel. Plus, at one time, there was no light on at the dash. Unfortunately, the owner of truck just passed so I have no way to get a timeline but the general consensus is that the door locks and the windows and the TPMS problems, all started happening at the same time or at least the windows and locks problems did.
TollKeeper
Brighton, CO
You verified there is a sensor, but is it broadcasting when activated?
Manual relearn procedure, Keyless Entry (2008-2014):​
  • OBDII connector is not required
  • Confirm TPMS sensors are properly installed
  • Adjust tire pressures to placard value
  • Inflate all tires
  • Turn ignition ON
  • Push and hold unlock and lock button on key fob until horn sounds
  • Use tool to activate LF sensor
  • Single horn sounds
  • Repeat for RF/RR/LR
  • Turn ignition OFF
Manual Relearn Procedure, DIC Button (2008-2014):​
  • Inflate all tires
  • Apply parking brake
  • Turn ignition ON
  • Push the DIC information button until PRESS TIRE LEARN is displayed
  • Push (✓) to confirm
  • Horn sounds 2x and TIRE LEARNING ACTIVE is displayed
  • Turn ignition OFF
  • Release parking brake before driving vehicle
Manual relearn procedure, Odometer Reset (2008-2014):​
  • Inflate all tires
  • Turn ignition ON
  • Push and hold the trip odometer reset stem on instrument panel until PRESS (✓) TO RELEARN TIRE POSITIONS is displayed
  • Horn sounds 2x and TIRE LEARNING ACTIVE will display
  • Use the tool to activate the left front sensor
  • Single horn will sound
  • Repeat for the RF/RR/LR sensors
  • Turn ignition OFF
I believe you can also press the valve core at each wheel and start deflating each tire, until the horn sounds.
Start Left Front, Right Front, Right Rear, Left Rear
GMT800 SUV/Trucks
On the 2009 K1500, they believe they are going to sell the truck and don't want to go any deeper. I finished what they approved and gave the truck back to them this morning. It was the first time I had used the stretch belt install tool and it worked flawlessly. I have a great MAC tool 1/2" ratchet, long handle, and a 24mm socket and the belt went right on and there is no more noise at the a/c belt. When I did the oil change, I did identify 2 leaks. One from a loose old oil filter and the other from the oil cooler line block off flange. I explained to them what the repair would take and they will think about it. It is seepage leak and not a steady drip leak. Rest of the engine is dry.
TollKeeper
Brighton, CO
I did the manual relearn procedure with no positive results.
Check the 10A DSM fuse in the cab fuse panel.
Also, are the tires factory to the truck? Newer truck? etc? It may have sensors, but are they the correct ones? I know they changed the frequencies a couple times over the years.
GMT800 SUV/Trucks
I did check the fuse you mentioned and any fuses in there that had to do with windows and door locks and all looked good. I looked in the fuse/relay box under the hood with all looking good.
GMT800 SUV/Trucks
The 2007 Lexus got dropped at the detail shop today. Getting the full meal deal. Interior, exterior, engine compartment and polishing the headlights. When pick it up, am gonna do the work I listed in a previous post in this thread and put it up for sale.
On the way back with my AL friend he mentioned another retired friend is assisted living that is a vet and has a GM truck for sale and he asked if I was interested in going to look at it. We did. It is a 2005 GMC Sierra HD2500 Duramax crew cab 6.5 foot bed and is a 4x4. 194k miles on it. Has a cracked and non functioning power adjustable manual extension d/s mirror problem, dent at the left rear chrome bumper on the corner and a dent in the p/s rear bed area under the taillight. No rips or tears and starts right up and plan on in the next couple days getting it here to do a full on inspection. The center he is at is about 1 mile away. I am aware that by 2005 the injector problems had been addressed on the Duramax but it has it's own weaknesses on the LLY engine. The concerns that it has mainly happen under heavy load conditions or tuned high horsepower/torque conditions. I had a 2003 Duramax and loved it.
GMT800 SUV/Trucks
Picked up the 05 GMC Sierra Duramax today and brought here for inspection. Gobs of the Duramax power and smooth transmission shifts. Looked under hood and found slight seepage at the hydro-boost where the master cylinder bolts on. The master cylinder looks dry but the booster does have some wet on it. Steering gear has slight seepage at the shaft. Rear diff cover lower half shows seepage and has the dark brown wet dirt. Both front axle seals leak at the stub shafts. One is a leak, the other is seepage. Rock chip at upper 1/3 of p/s w/s.
Was all set to take it back and tried all the windows. The left rear went right down but stopped 1/2 way up. Went back down easy and then 1/2 way up and stopped but could hear a grinding crackling noise. No matter how I tried to help it up, it was stuck. Called him. said what I expected, "Worked fine the last time I used it". That could have been years ago. Back window of a crew cab and he can only get around with a rolling walker. Removed the inside door cover and tried it again and narrowed down the noise to where the cables go in and out of the motor housing. Then I found it. The cable is coming apart. See pics. I unhooked the window and taped it up so would no rain in and showed the guy the pics. He is having me fix that. I estimated the parts and labor for the rest of the work and with the broken mirror, the dent in chrome at left rear bumper and the dent under the right rear taillight. I explained that at best it is FAIR condition at KBB and figuring in the cost of the listed repairs, I offered him $4k cash. He does not get around and may likely get more at CL but then he has to deal with the crazy buyers and no shows and and and.......His son does not want the truck either.
GMT800 SUV/Trucks
Saturday at 10 am the son of my neighbor across the street is coming in with a 2005 Lexus RX330 with brakes that make a grinding noise when driving and is worse when apply the brakes. Golly, I wonder what that is?
Tomorrow get the Lexus IS350 back from detailer and I have the engine hood and trunk struts here to install and do an oil change and do the engine air filter and the cabin air filter.
Then it goes up for sale.
elianymanol
