There are just some days I wish I didn't turn wrenches
Multnomah Falls
Great to see you back at it!
I have actually ben doing some work but was mainly just oil changes. Then I find things that are needed and then they delay and save and then do the work later. New 21 year old girl up the street. Landlord told her to see me about a slight metal on metal brake rub when apply. I drove it and confirmed. Told her the pricing with my discount. She paid for parts. Then asked if I would take payments for the labor. I said no. then she asked if she can have the parts and when she came to get them, she said her dad is a "car guy" and is gonna do the work. I asked why she did not go to him in the first place. I told her that moving forward, I will not work on her 2010 Subaru Outback or any vehicles of the 2 other girls she lives with. Guess what she called me when she left, "A BOOMER". I LMFAO for about 10 minutes.
Multnomah Falls
Last two days have been back at it and busy.
Thursday night I had a customer drop off her 2014 Jeep Grand Cherokee for CEL and I had checked about 2 months ago and found evap related codes P0440 and P0456, related to purge valve and the charcoal cannister ESIM-Evaporative System Integrity Module. Did some research and found that they should be replaced in pairs and since the ESIM is mounted right on the charcoal cannister I replaced the complete cannister and the purge valve. After restart of engine and checking my scanner for codes, I found both codes gone in the Pending and Stored files but still in the Permanent files. I then researched and found that I needed to do several duty cycles and then see if Permanent codes go away. They did. The purge valve is located under the engine cover and the cannister/ESIM is located under the backside wheel well cover on the d/s rear. See pics:
20240727_074551.jpg20240727_074558.jpg20240727_074607.jpg20240727_074616.jpg20240726_115536.jpg
Multnomah Falls
Then came the second vehicle that I worked on yesterday around noon. 2000 Toyota Corolla that only has 87k miles on it and it looks it. It belongs to a neighbor that keeps it at the coast in his garage there. Very noisy blower motor that sounded like the bearing were out. He sprang for a Toyota assembly and I had it in case the complete unit needed replaced. Popped off the p/s threshold cover and removed the kick panel and then dropped the entire glove box assembly including the entire trim assembly. 2 10mm bolts at bottom and 3 phillips screws and give it a yank and it falls out. Then I could see the blower motor. I turned it on and put my hand on it and was definitely source for the noise. Unplugged the connector and 3 8mm screws and pulled it out. See pics of the rodent problem. I did reach up in to the cavity and found no pink insulation. Installed new unit and is very quiet.
20240726_130657.jpg?hash=d66e262e2cb16164b05b0f036a6847d0.jpg20240726_130729.jpg20240726_141439.jpg
TollKeeper
Brighton, CO
So my Envoy is my spare vehicle, and I have space in my Side Driveway to store it for when I need it...
However, it backs up to a open field.. I dont want mice. So I rather park it on the Concrete on the street in front of my house, than in the grass in the back...
Your pictures above are the reason why!
Multnomah Falls
If you buy enough from RA, they will send you codes too and then post them here.
I buy, on average, up to $400 a month at RA, for the vehicles I work on here.
I have a used to be neighbor that bought a used Chrysler Town & Country Touring Edition mini van, for his family, and it needs front struts. I will only buy the loaded assemblies and can get them at RA for $105 each plus the code savings. Local Auto Zone is $260 each and I get 10% off there but the struts can wait for the RA shipping.
Strangely enough, the struts for the 2015 Town & Country, were saved in my shopping cart and when I got the ok yesterday evening from the vehicle owner to go ahead and order them, I found that the struts had gone down $10 each in price. Another $20 savings. If anyone looks at a you tube video for replacing the struts, they will see that the upper cowling removal is required for access to the top strut plates mounting nuts. There is a rubber seal that runs across the top of that cowling and lays flat against the bottom area of the w/s. The existing one on the Town & Country, has broken/split/missing rubber edges all across that seal. I told him that has to come off to do the struts, so there is no additional labor.
Located the cowling at ebay ranging from $400+ to $268 with free shipping. He was smart and I ordered the cowling too. Now he will save for the labor.
Multnomah Falls
Put a new grille and Chevy BowTie on my girl's 1990 K2500 today. Old grille chrome was coming off and the old black part of grille was pitted and turned grey. I also replaced the upper fan shroud because the old one was breaking apart. The first 2 pics are the old grille and the old BowTie.
20240823_153230.jpg20240823_173750.jpg20240823_170936.jpg20240823_165743.jpg20240823_165756.jpg
Multnomah Falls
Next up for the 1990 K2500 5.7 is intake gaskets, valve stem seals, egr gasket, TBI gasket and cleaning for the IAC, new heater hose connector at the p/s rear, valve cover gaskets, new a/c clutch assembly and thermostat and housing.
Oil and filter of course.
JJones07tahoe
