Thinking about buying a 2dr Yukon gt
K
Kool rider28
little rock ar
Walking away slowly
Went to talk the owner again and verify the a/c. It didn't work and he would not vome off the price. I had money in possession and everything. He couldn't get to go in neutral bc linkage not connect.
Well if anyone in the little rock Ar area selling a 2 door let me know
Administrator
You did the smart thing to walk away from that deal, man :Handshake: There was more wrong with that than probably the owner actually knew!
lilman
Hartford,Ct
Give it a few weeks. He'll take $800 for it, easy. Unless he finds some other sucker to buy it. Just wait it out.
raptorforme93
Tampa, Fl
Good luck man! You will be much happier if you hold out and buy the truck that you want than if you settle for something that isnt quite right.
Administrator
Let us know how it goes :waytogo:
K
Kool rider28
little rock ar
93 blazer one thumb down
Checked out the blazer today. Motor seemed strong but 4wd high didn't work. Put it in 4wd low and it work. Also trans won't down shift to 1st gear. Had to manually put it in 1st and then shift into OD. Needless to say I will pass. The funny thing about the trans was that it was just rebuild and the technician said the problem had some to with electronical side. So he didn't fix it. Must be a hard fix or expensive fix because the owner didn't fix. Also the air conditioner panel wasn't connect so no A/C or radio.
Administrator
you're smart to pass on that one!
Jeremytahoe
