Plimbob
Well Gents,
I tried the 3 minute on , 60 seconds off relearn process unhooking the battery for 15 minutes first. Results:
1st attempt after dis-engaging battery
It ran up to 1,000 at the start and idled down over about 1 minute to around 600. I let it run 3 minutes and shut it down for 60 seconds
2nd Attempt
It immediately ran up to 1,200 and started climbing higher to where I shut it down at around 1,800 which took about 45-50 seconds. It was still climbing so I shut it down.
Repeated the unhooking of the battery and tried it again. Almost the same exact results except on the second attempt the engine ran up to 2,000 very quickly. I shut it down.
I think I am back to driving it to try and get it to relearn if it's still erratic after tomorrow I think I'll take it in and have it reset. I have to drive 350 miles RT on Thursday to a business meeting.
Nate, Wes and Tony - thanks much guys for your help on this. I'll keep you posted.
As an aside - the truck is running much better when it isn't a screaming meme at idle.....
Thanks,
Tim
2nd Attempt
Thanks,
Tim
