tire pressure monitors...anyway to turn them off?
ohiokon
If you know someone with a GM tech 2 tool you can remove just about anything you want to out of the BCM. The BCM should be where most of the RPO codes are stored. Basically you pull the RPO codes out of your BCM with the tech 2. DO some research and find out which code or codes are for TPMS. Next step involves a dealership. If you have a friend with a tech 2 he can get this done for you probably for free. You need to hook the tech 2 up to the computer at the dealership and look through all the codes until you find the ones you want. Once you find them remove them and reload the new info to the tech 2. Hook the tech 2 back up to the truck and reflash the BCM. The hard part is finding someone that has a tech 2. The dealership will not remove a safety feature from your ride period! You can also shut off the service suspension message when you disable autoride by removing the 2 rpo codes for autoride from the bcm. The truck will never know it even had autoride or TPMS. Goodluck and if you are wandering how I know this my buddy has a GM tech 2 tool!
macking
