Tires scrub even with lift! Help plz
jESse
i like cheese
michigan
get a different front bumper that gives you more clearance or drop a tire size. those tires look about shot anyways
yates ™
Resident Apple hater
Iowa
Smaller tires, bigger lift, or see if you can get another inch out of the torsion bars but becareful of your angles.
01Konvict
Boats n Hoes
Raleigh/SML
keys lift the front end more, your rubbing looks like it is from tire width. What is the offset of the rim (example 18x9 +18mm offset)? Give me rim and tire details. I think the tires will work with lift keys. Take your stock keys out and replace with lift keys and you can get 2" lift in the front.
yates ™
Iowa
I knew someone would chime in with more/better info then I can give :Handshake:
F
Frankie21
Eastern North Carolina
Sorry for being a newb but how exactly do i figure out the offset of the rim?
Im trying to learn something new haha
yates ™
Iowa
It should be stamped on the back of the wheel
yates ™
Iowa
That link shows them at -12mm offset
lordmorgul
