Told no kits to lift 2023 z71 air suspension with magnaride…… please help
Kpwweb
Why do you buy an air ride 23 Tahoe and then want to lift it 3"?
How about larger tires and it does not look like every other momobile Tahoe? Air ride gives more adjustability over fixed springs. And I can lower it when I need to wash it.
Biggest thing though is it came with the package that had the other options I wanted, and it was on the lot.
jd08
Jackson, WI
We like our air ride. It does wobble some times but when we hook up the trailer it will level it and also firm up the rear for better stability.
I used edgymods links to lift ours a lttle over 1.25".
CCPLuvr
Got the same suspension on my AT4 and lifted it about 2.5" using the edgymods.com links. They're pretty easy to adjust and install yourself.
Regarding the ride quality of air our impression is it's much smoother than the normal suspension.
OffBrandCornDog
