I don't have any software to tune. Wish I knew how to do that. Mine was tuned previously with the same cam specs as the replacement. That's why I got the cam that I did. I want to get the pcm tuned to turn on fans. Someone posted a link to a guy who does that for $50--but I can't find the link. Anyone know who I'm talking about?
I have the software and was tuning my LT1 build years ago for a new cam. that motor was stupid fun. Got the valves opening better part of an inch. Sounded like a nascar especially because I had straight pipes haha
The fuel maps are a PITA so I ended up just adjusting overall trim I think, idle speed, and a few other things. Then I mailed PCM off to a shop that had a tune for my cam. I gave up haha Nearly impossible to tune without a dyno and wide bad O2.
I boight HP tuners for my vette as I was going to buy a super charger or twin turbos... then called tobbn place the order for a supercharger and litterally changed my mind on the phone haha I can already break tires loose in 4th gear. supercharger would just be stupid unusable levels of power. I was told tuning foe forced induction is much easier than a cam so bought the programmer. thankfully works on my truck too
I would swap the tune over for you if you were here in AZ :/
Is fun to have software tho can make little tweeks here and there. I also wish I knew name of the free program to download amd flash the PCM then you could just transfer your tune to the new motor assume is same size, cam, and injectors.
Sent from my SM-A505U using Tapatalk
