Tonyrodz's Tahoe Build Thread
Fless
Super Moderator
Elev 5,280
I'd be curious to know if you think it changed your speedometer readings, after you drive it for a bit.
Me too lol. It was pretty accurate up to 50 mph, after that it would read around 3 mph or more faster. So if I was doing 75 it would say 78. I know because I always have my gps on.
The speedo must be calibrated in the TCM because Blackbear adjusted mine a couple times for different tire/wheel sizes. So unless you’re programming the TCM using SPS you won’t be able to do it with the Tech2. You need to flash the TCM afaik.
I've had an issue for awhile--slowing down and coming to a stop, the pedal would pulsat as I came to the stop. The abs would kick in. So today I took off the ds front abs sensor and cleaned the magnet pickup. There wasn't really any debris, but I cleaned it off anyway, and sprayed a bunch of brake clean inside the hub. Still does it. I also swapped out a clogged zerk on the ds lower bj. That's good now. Still gotta do 2 on the ps.
Rome58
