Tonyrodz's Tahoe Build Thread
I'm def not motivated enough, especially to do it on the ground.
That’s my problem, when I was thinking about doing my exhaust on my Silverado. It’s one thing if it’s up on a lift but trying to do exhaust while laying on your back just seems too much for me. Just doing mechanical work is hard enough, every tool is just out of reach and I end up climbing in and out from under there a hundred times. Fitting exhaust pieces and then welding when it’s basically right in your face…no thanks.
Heard!
I've burnt my face having to remove my hood to fit my melon up high enough to see the top of the exhaust pipe. I'd aim my gun, squint really hard, purse my lips, pull the trigger and move the gun by by memory and trying to imagine where my hand was and how the bead was laying. Tried two pairs of dark tinted safety goggles, too. Eyelids and cheeks felt like sandpaper the next morning. I also looked like I had acne.
When working on the exhaust tip, I lowered the lift to put the exit right at eye level. I looked into the pipe and focused on the light coming through the thin gap in the joint (butt weld). I reached up behind the bumper cover with the gun and watched the metal in the pipe glow orange. I kept the hottest part (yellow) on the joint and guessed my bead location that way. Did surprisingly well. I tend to give fewer fcuks when welding exhaust unless I know it'll be my permanent iteration.
Heard!
My kid welds. Of course he lives 3 hrs away.
Hobbitsam
