Tonyrodz's Tahoe Build Thread
Fless
Super Moderator
Elev 5,280
Did you find the menu to reset the long term fuel trims? I would recommend that, but I'm not seeing anything amiss. It goes into closed loop and the short term fuel trims are dead on, well within the desired management window.
Only 1 misfire in 4 cycles of misfire data on a couple of cylinders, nothing to worry about. If you collect more cycles, do the misfire counts go up?
No, they don't go up. I looked all over the menus to reset fuel trims but couldn't find it. Can they be reset on the NBS? Or is it just the NNBS?
Fless
Super Moderator
Elev 5,280
To reset the long term fuel trims, connect the Tech 2 and enter your vehicle information, and go into the Powertrain menu. Of course you'll want to be in the Diagnostics menu.
> Special Functions
> Fuel System
> Fuel Trim Reset. It collects some data for a few seconds.
On the next screen the fuel trims are shown, and a soft menu item "Reset" at the bottom of the screen should appear. In order to select it, press the corresponding soft key (just below the screen) once -- or you might need to do it a second time -- and the LTFTs should reset to zero. (Since the engine is not running, the STFTs are static at 0.)
HiHoeSilver
Away!
Chicago
> Special Functions
> Fuel System
On the next screen the fuel trims are shown, and a soft menu item "Reset" at the bottom of the screen should appear. In order to select it, press the soft key (just below the screen) once -- or you might need to do it a second time -- and the LTFTs should reset to zero. (Since the engine is not running, the STFTs are static at 0.)
Earning that moderator badge!
jangel
