Uhhh... Yes?
- Full 1/4 and 3/8 socket set. Shallow and deep, 4mm to 24mm plus 1/4"
- Half inch set 15, 16, 17, 18, 21, 22, 24, 32
- Half inch ratchet and breaker bar
- Extensions for all, ranging from 1" to 10", with the 3/8" ones locking
- 1/2, 3/8, 1/4 torque wrenches
- Multimeter
- OBD scanner
- IR camera
- Hose pliers
- Multiple screwdriver sets
- Small / large hammer
- RTV, silicone, moly grease
- Hose picks
- Extractor socket sized appropriately for lugnuts
- Soldering iron, solder, wire strippers, couple misc spools of wire
- Flashlight
- Blowtorch
- Hose picks
- Spare fuses, relays, headlight and high beam bulbs
- Full array of pliers. Needle nose short, needle nose long, lineman's, blunt, S/M/L knipex
- Gloves
- Torx set ranging from t10 to t70
- Inverse torx set (forgot sizes, it doesn't get used often)
- Heat shrink
- Some panel/clip tools
- Pack of razor blades
- Zip ties
- Electrical and gorilla tape
- Superglue
- Spare blanket, clothes, flares, jumper cables
- Spare coolant, oil, p/s, brake, trans fluid
- Bag of rags and microfibers
- Roll of butyl
- Couple towels
Edit: Remembering more things
- Tow strap
- Shovel
- Ice scraper
- Solar battery tender
- Pipe cutter
- Couple feet of spare hose, varying sizes
I think that's about it? Might be a couple more small items in there. But like, barring anything that needs a puller I can handle most anything along side the road. Maybe not well, but enough to limp to wherever.
