Top Speed
the blur
Cyber Space
What's your top speed... with the governor ?
I hit 101 going up hill. Surprisingly, going downhill, The governor interferes more, and I couldn't break 100.
It's an interesting fuel curve gradual cutoff. It's not abrupt, it just seems to limit the fuel, but the engine still revs decently.
This is on a 2014.
T
the blur
Cyber Space
It's interesting. Between the GPS, and the digital speedo, you can pretty much know your actual speed. And what's even more interesting, the speed limiter is not a set speed. It will keep on pulling, albeit very slowly. Until it won't pull any more. And it changes on condition, such as terrain, RPM, tow mode, etc.
T
the blur
Cyber Space
It's 100% stable at speed. 20" tires, no problem. If you road force balance your tires, it makes a difference.
Also, it helps I have 20,000 miles on track experience.
yates ™
Resident Apple hater
Iowa
Do want to see 20" wide tires on a Tahoe.
fiatdale
Houstons Best
Houston
Must be 'Merican Force. I was going to make the same statement but knew someone else would chime in.
yates ™
Iowa
That is more merican than merican force, I think they just go to 16" wide.
fiatdale
Houstons Best
Houston
Wow. I gotta see this. Gonna need a lot of power to push 20" wides to 100mph.
Ali Hawi
