torison bars
SunlitComet
OBS Jedi-Do Good
unknown at this time.
They actually might. I know t-bars from a 95 Tahoe went to a 2000 1500 on the4 application chart. Go to compnine find the part you are interested in on the vehicle it comes off of and click on the part number for other applications it fits.
the big blue bus
the big blue bus
richmond, va
i might have to try em and see if they are indexed differently. if all my bj boots are ripped and greases commng out it a good idea to just go ahead and replace em? going now to figure what else is worn in the steering. seems like idler arm is where im getting play or inner tie rod on passenger side. drivers is all tight and no play
the big blue bus
the big blue bus
richmond, va
where have yall orderd yalls from? guess need all bjs and idler arm. shouod i replace the tie rods too? they sell kits on ebay with all the stuff has anyone used them?
SunlitComet
OBS Jedi-Do Good
moog parts. I got mine from amazon. could also get from rock auto or local stores. Do not buy ebay. And check for loose rods before you just replace them.
the big blue bus
the big blue bus
richmond, va
wil look there. got the keys from the truck today. any one know for sure if they will be anny diff then what i have? going to get the bjs and idler arm and replace them and keys sometime soon. got the keys swaped on the 2000 1500 went real easy actually. on mine though i have a crossmember behind the t bar one so gettin to hit the bars forward like we did on his truck wont be as easy but i hope my truck will be just as easy when we do it
steamroller
The South
I knocked mine out from the front with a piece of pipe. Just a guess but they are probably the same. If I'm not mistaken the Ford keys fit both body style trucks.
I would try the bars that were removed from the truck while I had them out though.
the big blue bus
the big blue bus
richmond, va
well he only got keys thought he got bars to when i was taking to him. the part # on the keys i have outa his truck is 15530030 and then has WN20 and 315 on the end of it.
so far come up with these parts i need...
http://www.amazon.com/Moog-K6292-Up...hevrolet|47&Year=1995|1995&newCar=1&carId=001
http://www.amazon.com/Moog-K6447-St...hevrolet|47&Year=1995|1995&newCar=1&carId=001
are these the right lower bjs?
http://www.amazon.com/Moog-K6477-Lo...hevrolet|47&Year=1995|1995&newCar=1&carId=001
SunlitComet
OBS Jedi-Do Good
the lower arm joints depend on if your lower arm is stamped steel or forged. The ones you listed are for stamped which is most likely the correct one for a tahoe.
BruceWayne
