Torsion keys
bowtiefreak
No Quarter
Near Philly
shocks are not load bearing, the springs are. Shocks just slow down the reaction of the leafs. The driver typically is the lower side on 4 drs due to the gas tank. This could be something as dumb as differently tightend U bolts.
Smasal
Smasal
Southwest, Mo
Gonna check u bolt tightness later. Hopefully it's not something serious.
Smasal
Smasal
Southwest, Mo
Measured again. 36.8 on rear driver side. Passenger 36. It is stock as far as I can tell. Can I loosen nuts on ubolt? Too see if it relieves the 3/4 inch difference? Or?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It wont. And once you do that you should reuse them.
---------- Post added at 07:49 PM ---------- Previous post was at 07:49 PM ----------
replace your springs and be done with it.
Trippers99hoe
SW Oklahoma
I think sunlit meant should not reuse the u-bolts. we always use new U-bolts they are cheap.
Smasal
Smasal
Southwest, Mo
I'm confused man. Do or don't loosen em? If there is one tighter than the other why wouldn't that be the issue? And reuse them, or replace them? I'm hoping for an easy free fix.
Smasal
Smasal
Southwest, Mo
Okay Ty for clarifying. But will just loosening them not work? I mean like torsion keys for example. I can just loosen or tighten them anytime I want. U bolts aren't the same?
Trippers99hoe
SW Oklahoma
no the u-bolt is not adjustable,you don't want anything moving back there. If nothing is broken or loose just drive it until you can afford new spring packs.
Smasal
Smasal
Southwest, Mo
That's what I was afraid of. I will have to look tomorrow. I keep putting this off I know but I'm a single daddy and little man is fighting bedtime hard right now. But all is well. I have noticed on a notoriously steep hill in town, when I turn right, I can hear a sound like a moan. Lot of stress on a shock or something up front.
Jordan0277
