Torsion keys
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I think sunlit meant should not reuse the u-bolts. we always use new U-bolts they are cheap.
Thank Trip goofed on that one.
Do not loosen and do not reuse once loosened . nuts or u-bolts.
---------- Post added at 09:03 PM ---------- Previous post was at 08:59 PM ----------
That's what I was afraid of. I will have to look tomorrow. I keep putting this off I know but I'm a single daddy and little man is fighting bedtime hard right now. But all is well. I have noticed on a notoriously steep hill in town, when I turn right, I can hear a sound like a moan. Lot of stress on a shock or something up front.
If noise is happening as suspension is traveling up and down then it is usually a bushing.
Smasal
Smasal
Southwest, Mo
Look okay? Only a half inch difference now. Tires are crap. Could be the issue.
Ch@d
Smasal
Smasal
Southwest, Mo
Absolutely nothing. Not sure whats up. Is half an inch okay? I know pics are small but I cant tell that theres anything wrong at all. Im confused for sure. Is that a small lift I have in there or is that stock?
Trippers99hoe
SW Oklahoma
I wouldn't sweat a difference of 1/2 inch ,looked stock in the pics
If it was me ,I would take it for an alignment(since you changed the ride height by adjusting the torsion keys)Get the alignment(camber,caster and toe) right so you don't wear tires and components out.While it is on the rack have the tech measure your height on all 4 corners.
Josejr00
